Cloning the SBL
To clone the repository from this server, run the following command:
> git clone git://sbl.inria.fr/git/sbl.git
In order to compile the applications, one must set the environment variable SBL_DIR to the path
of the local repository hosting the library.
To update one’s version of the library, upon moving into the sbl repository, simply type the command:
> git pull
